21 years agoService Pack 1, Nios II 1.0
Service Pack 1 for the Nios II v1.0 release is now available for free download: nios ii 1.0 sp1 (https://www.altera.com/support/software/download/service_packs/nios/dnl-nios2_1_0_sp1.jsp). This serv...
21 years ago --- Quote Start --- originally posted by niosiiuser@Nov 5 2004, 02:43 AM hello jdkirby,
it?s the same behaviour with the stand-alone lwip from microtronix. the sp 1 for nios ii should be installed after adding uclinux (or stand-alone lwip) to your system.
1. uninstall your nios ii 1.0.1
2. install nios ii 1.0
3. install uclinux
4. install sp 1 for nios 1.0
bye,
niosiiuser --- Quote End --- That makes sense. Upgrades and patches were available when I first installed on this computer and I didn't bother to RTFM. Foolish mortal! This is the error you get installing Nios II SP1 if you do it Leslie's way: The directory: c:\altera\kits\nios2 Does not contain the expected Nios II installation(found 1.01). Please select a directory with an installation of Nios II 1.0 to continue. I assume I will have to uninstall and reinstall Nios II and uClinux at some point.
