21 years agoSelective Cache Enable/Disable support
Does NIOSII processor support selective caching of the entire system-address space. For example in system address space we have the SDRAM, and all other addressable-peripherals. Whenever any peripheral region is addressed by registers the s/w does not expect processor to read data from cache instead directly from regs for latest update. And in Linux we use the request_io_region() with cache support disabled for those memory ranges, however the processor has to support cache disable for specific regions of memory right ? --- Quote Start --- If my understanding is correct most linux drivers wont work if it would disable-cache for peripheral addressable register ? Am i Correct ?2 Replies
The CPU let's the software decide on each access to memory whether it wants to bypass the D-cache or not.
The software can either use the ldio/stio family of instructions to bypass the D-cache or can just set bit 31 of the address to 1. There are HAL macros to hide this from most users. I don't know what Linux provides. - Altera_Forum
the linux provides the following facilities to read/write io regs:
inb/outb, inw/outw, inl/outl, ... the following to read/write device memories (bypass caches): readb/writeb, readw/writew, readl/writel. these facilities are implemented using cache bypassing instructions. If you want to read/write IO regions like normal ram access, you can use the 31 bit address line. Without an MMU, uClinux has no other way of bypassing cache for specific region.
