BeB
1 year agosegmentation fault with nios2-terminal and printf/alt_printf statements
Hello, I am running into segmentation faults using either alt_printf or printf to output debug messages from a nios 2 application via the nios2-terminal application. The code runs fine without the ...
tehjingy_Altera
1 year agoHi
That is very weird.
One thing could you try is to run just a simple hello world to see if it is working?
If it is fine with you could you share your project and I can try to have a look at it?
Jingyang, Teh
BeB
1 year agoHello,
Sorry for the late reply.
A simple 'hello world' works fine.
It seems that changing the size of the stdout uart buffer solved the problem. A too large buffer causes the segmentation fault. Reducing the buffer size eliminated the issue (with the exact same code otherwise!).
Thank you,
Bertrand
