20 years agoSDRAM access speed?
Using Nios II & SOPC builder, I'm trying to design an DMA to SDRAM interface that will transfer data from an on chip ram to SDRAM using DMA.
I used ModelSim to test my interface and found that I can have an SDRAM access speed of ~40MB/s. Have anyone been able to go at a higher access speed than that? I have done many things to make the speed faster and allow larger transfer of data trunk. I set the SDRAM controller clock and SDRAM pll to 75 MHz (tried 80 but failed). My DMA controller and on chip ram clock is set at 100 MHz. The arbitration# between DMA and SDRAM is set at 64. Also, my on-chip ram size is set to 16KB and DMA's length is 16. Does anyone have any other suggestion that will allow me to speed up the SDRAM access speed? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Thanks a ton for your reply...2 Replies
--- Quote Start --- originally posted by quin_crc@Dec 15 2005, 12:28 PM using nios ii & sopc builder, i'm trying to design an dma to sdram interface that will transfer data from an on chip ram to sdram using dma.i used modelsim to test my interface and found that i can have an sdram access speed of ~40mb/s. have anyone been able to go at a higher access speed than that?
i have done many things to make the speed faster and allow larger transfer of data trunk. i set the sdram controller clock and sdram pll to 75 mhz (tried 80 but failed). my dma controller and on chip ram clock is set at 100 mhz. the arbitration# between dma and sdram is set at 64.
also, my on-chip ram size is set to 16kb and dma's length is 16.
does anyone have any other suggestion that will allow me to speed up the sdram access speed? http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/unsure.gif
thanks a ton for your reply...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11589)
--- quote end ---
--- Quote End --- Sorry about unable to answer your question. But want ask you how did you get on-chip RAM address mapped onto avalon bus. I am proposing to transfer more than 10K memory contents to SDRAM by DMA. Thanks a lot, and sorry for bothering.
Are you using the PLL output directly to the SDRAM clock? I think you must screw it by a few degrees relative to your NIOS clock. From what I can remember some of the example designs demonstrates this.
VictorS
