20 years agoSDRAM access speed?
Using Nios II & SOPC builder, I'm trying to design an DMA to SDRAM interface that will transfer data from an on chip ram to SDRAM using DMA. I used ModelSim to test my interface and found t...
20 years agoAre you using the PLL output directly to the SDRAM clock? I think you must screw it by a few degrees relative to your NIOS clock. From what I can remember some of the example designs demonstrates this.
VictorS
