21 years ago
RUN AS HARDWARE error
After I install Quartus5.0 Nios5.0,I find these errors comes out frequently.
Using cable "ByteBlasterII ", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x02000908: verified
Downloading 01000020 ( 0%)
Downloading 01010000 (98%)assertion "m_state == STATE_DEBUG" failed: file "nios2
debug.cpp", line 1695
Signal 6
Pausing target processor: not responding.
Resetting and trying again: assertion "m_state == STATE_DEBUG" failed: file "nio
s2oci.cpp", line 226
Signal 6
Downloading 01010000 (96%)
Downloaded 67KB in 1.9s (35.2KB/s)
Verifying 01000020 ( 0%)
Verify failed
Leaving target processor paused
    no, i changed someting, or else i can not use flash programmer!
    Hmmmmm ...
    it was just an idea as we had exactly the same messages after we moved from Q4.2 to Q5.0 with a project that was created with q4.1 (with nios1.1) and we were unable to use the flashprommer too but quartus prommer via JTAG and signaltap worked. even the ide debugger worked !
    it was just the ide that had problems with our target using the flashprommer
    back to q4.2 and everything was fine.
    So we just created a new "mktarget..." board under q5.0 nios5.0 and those messages went away without a single change in our project except a recompile under q5.0 pointing to this new target board
    hi mountain8848,
    you said " The fact :
    1. Using ByteBlasterII will cause those error.
    2. Using ByteBlasterMV turn out OK!
    I use byteblasterMV to try the run... function, but the niosII display jtag device can not surport this download cable, maybe the cyclone device only surport byteblasterII or usb blaster, how do you use byteblasterMV as a jtag cable?
