21 years agoRUN AS HARDWARE error
After I install Quartus5.0 Nios5.0,I find these errors comes out frequently. Using cable "ByteBlasterII ", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x0200...
21 years agoHmmmmm ...
it was just an idea as we had exactly the same messages after we moved from Q4.2 to Q5.0 with a project that was created with q4.1 (with nios1.1) and we were unable to use the flashprommer too but quartus prommer via JTAG and signaltap worked. even the ide debugger worked ! it was just the ide that had problems with our target using the flashprommer back to q4.2 and everything was fine. So we just created a new "mktarget..." board under q5.0 nios5.0 and those messages went away without a single change in our project except a recompile under q5.0 pointing to this new target board
