BrendenB
1 year agoRiscFree v25.1.1 no longer finds BSP and compiler headers files when editing
A fresh project imported into RiscFree v25.1.1 never resolves the header from the BSP or compiler while editing. For example: This means that autocomplete of functions does not work. It works in...
- 1 year ago
Hi
Thanks for raising this issue and providing the workaround.
I have raised this issue to our technical team.
At the meantime please bare with the tool and use the workaround you found.
Jingyang, Teh
BrendenB
1 year agoI also wanted the mention that you can use the "Project > Properties > C/C++ General > Preprocessor Include Paths > CDT User Setting Entries" as in the images above to manually enter in all the paths. You may need to enable the "CDT User Setting Entries" on the "provider" tab before manual paths can be configured in the "entries" tab.
