16 years agorequest_mem_region() error in uClinux
Hi All,
I am new to uClinux and NiOS II. I have been trying to make the ethernet work under uClinux with no success. I followed the ethernet link in nioswiki but keep getting the errors: *****ATSE:../../../nios2-linux/linux-2.6/drivers/net/altera_tse.c:1671:request_mem_region() failed atse: probe of atse.0 failed with error -16 0: New Bus ID Altera TSE MII Bus: probed Found phy with ID=0x20005c90 at address =0x01 Altera TSE MII Bus: MDIO bus registered ERROR: ../../../nios2-linux/linux-2.6/drivers/net/atera_tse.c:1652: request_mem_region() failed altera_tse: probe of altera_tse.0 failed with error -16 Note: uclinux is starting and I can use the bash. ifconfig shows only lo: local loopback Any pointers on how to solve it ? Thanks in advance6 Replies
Thank you for your reply.
I have already checked this thread but could not much understand what should be done. Additionally I am using a MMUless system, and the thread targets NiOS with MMU, can the information posted on that thread still be used in my system ? Regards - Altera_Forum
Ok got it, I had to modify atse.c and altera_tse.c
thanks to the following thread alteraforum.com/forum/showthread.php?t=18802 here are the modifications: * in atse.c, replace ----------
by:if (!request_mem_region(res_sgdma_rx_mem->start, res_sgdma_rx_mem->end - res_sgdma_rx_mem->start + 1, ATSE_CARDNAME)) { printk("******ATSE:%s:%d:request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out; }
andif (!request_mem_region(res_sgdma_rx_mem->start, res_sgdma_rx_mem->end - res_sgdma_rx_mem->start + 1, ATSE_CARDNAME)) { reg_resource = __request_region(&iomem_resource, res_sgdma_rx_mem->start, res_sgdma_rx_mem->end - res_sgdma_rx_mem->start + 1, ATSE_CARDNAME,0); if(reg_resource != NULL && reg_resource->flags & IORESOURCE_BUSY) { printk("******ATSE:%s:%d:request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out; } }
by:if (!request_mem_region(res_sgdma_tx_mem->start, res_sgdma_tx_mem->end - res_sgdma_tx_mem->start + 1, ATSE_CARDNAME)) { printk("******ATSE:%s:%d:request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out; }
* in altera_tse.c, replace ---------------if (!request_mem_region(res_sgdma_tx_mem->start, res_sgdma_tx_mem->end - res_sgdma_tx_mem->start + 1, ATSE_CARDNAME)) { reg_resource = __request_region(&iomem_resource, res_sgdma_tx_mem->start, res_sgdma_tx_mem->end - res_sgdma_tx_mem->start + 1, ATSE_CARDNAME,0); if(reg_resource != NULL && reg_resource->flags & IORESOURCE_BUSY) { printk("******ATSE:%s:%d:request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out; } }
byif (!request_mem_region(sgdma_rx_base, sgdma_rx_size, "altera_tse")) { printk(KERN_ERR "ERROR: %s:%d: request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out_sgdma_rx; }
andif (!request_mem_region(sgdma_rx_base, sgdma_rx_size, "altera_tse")) { reg_resource = __request_region(&iomem_resource, sgdma_rx_base, sgdma_rx_size, " altera_tse" ,0); if(reg_resource != NULL && reg_resource->flags & IORESOURCE_BUSY) { printk(KERN_ERR "ERROR: %s:%d: request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out_sgdma_rx; } }
byif (!request_mem_region(sgdma_tx_base, sgdma_tx_size, "altera_tse")) { printk(KERN_ERR "ERROR: %s:%d: request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out_sgdma_tx; }
* in both files, and at the beginning of the functions where we made the modifications declare reg_resource by adding the following lineif (!request_mem_region(sgdma_tx_base, sgdma_tx_size, "altera_tse")) { reg_resource = __request_region(&iomem_resource, sgdma_tx_base, sgdma_tx_size, " altera_tse" ,0); if(reg_resource != NULL && reg_resource->flags & IORESOURCE_BUSY) { printk(KERN_ERR "ERROR: %s:%d: request_mem_region() failed\n", __FILE__, __LINE__); ret = -EBUSY; goto out_sgdma_tx; } }
after compiling and downloading the image I was able to start eth0 by typing : # ifconfig eth0 upstruct resource *reg_resource; - Altera_Forum
--- Quote Start --- Ok got it, I had to modify atse.c and altera_tse.c thanks to the following thread --- Quote End --- These are two separate drivers. In menuconfig, they are the experimental and SLS driver, respectively. You shouldn't be using both at the same time. - Altera_Forum
OK, that explains why I have the errors I describe in my following thread (I think)!
Can you please take a look at it and give me your feedback ? - Altera_Forum
hi, i had the same problem
after the modifications works my ethernet korrekt, but I become the following errors: physmap-flash physmap-flash.0: Could not reserve memory region physmap-flash: probe of physmap-flash.0 failed with error -12 can anybody help me?
