16 years agorequest_mem_region() error in uClinux
Hi All, I am new to uClinux and NiOS II. I have been trying to make the ethernet work under uClinux with no success. I followed the ethernet link in nioswiki but keep getting the errors: *****...
16 years ago --- Quote Start --- Ok got it, I had to modify atse.c and altera_tse.c thanks to the following thread --- Quote End --- These are two separate drivers. In menuconfig, they are the experimental and SLS driver, respectively. You shouldn't be using both at the same time.
