Remote system upgrade for MAX 10 with Cypress quad SPI Flash
Thanks Pedro for your confirmation.
This is a helpful design example for using serial flash device. you can download it and know how to use this IP.
Hello @Ahmed_H_Intel1,
I am using the Generic Serial Flash Interface intel FPGA IP with Cyclone V E FPGA and Micron MT25QL256.
While using NIOS II Flash programmer GUI, I get Error code 4 for nios2-flash-programmer when I add .elf and .sof file, and try to burn it in FLASH.
Also, I tried using Prime Programmer.
I combined and convert .sof and .elf to .hex using command line and finally to .jic file using Convert Programming File GUI. My program didn't get properly burned in flash.
I want to have both hardware and software in flash.
Other issue that I am facing is, when I use intel_generic_serial_flash_interface and put reset vector of NIOS II to intel_generic serial flash memory. I get the following error when generating BSP file.
Error executing 'nios2-bsp-generate-files --bsp-dir . --settings settings.bsp', unexpected return code 1.
Error message:
SEVERE: CPU "nios" reset memory "intel_generic_serial_flash_interface_top_0_avl_mem" has no matching memory region.
SEVERE: nios2-bsp-generate-files failed.
If you could please answer the above mentioned queries.
Ahsan
