Paul83
2 years agoread/ write with IORD_32DIRECT and IOWD_32DIRECT problem
Hi All, I am using the quartus pro 23.4 with Asling 23.4.1 I have used the avalon_slave bus in my own module. After building the BSP and I try to run the IORD_32DIRECT (base_address) or even IOWD_3...
symmt_Intel
2 years agoHi Paul,
You mean you can now see correct waveform on signal tap by changing address bit width?
Sho Yamamoto
