Paul83
2 years agoread/ write with IORD_32DIRECT and IOWD_32DIRECT problem
Hi All, I am using the quartus pro 23.4 with Asling 23.4.1 I have used the avalon_slave bus in my own module. After building the BSP and I try to run the IORD_32DIRECT (base_address) or even IOWD_3...
Paul83
2 years agoHi Sho,
Thanks for your response.
In the platform design the base address from 0x00100000 to 0x0013ffff for the 16bit address on the avalon bus.
This time the abnormal is different. When I use the IOWR_32DIREC function, the read pulse is appear. It is very strange.
However, I try to change the address bus width to 12 bit, the base address 0x00058000 to 0x0005bfff. The signal capture from signal tap analyzer become normal.
Paul
