Paul83
2 years agoread/ write with IORD_32DIRECT and IOWD_32DIRECT problem
Hi All, I am using the quartus pro 23.4 with Asling 23.4.1 I have used the avalon_slave bus in my own module. After building the BSP and I try to run the IORD_32DIRECT (base_address) or even IOWD_3...
symmt_Intel
2 years agoHi Paul,
Looking at the VHDL code, it seems to me that there is no part which causes such errors.
Could you check if the memory address you access is correct?
What are the address of the memory you want to r&w (configured on Platfor Designer), and AVALON_TIMEOUT2_0_BASE?
Sho Yamamoto
