NGord
1 year agoNiosV
Hi I am in the process of converting a MAX10 Nios2 design to a MAX10 NiosV. It boots from Flash loaded into DDR All is good with the compiling apart from I need to convert the elf file to a hex fi...
Finally I have something that almost works.
Use Ashling IDE 24.1.1 "import niosv cmake project" and build project.
Downloading the elf file works either with Asling IDE 'Run as' or NiosV command shell niosv-download!
It doesnt run from External Flash though I do know
elf2flash and
riscv32-unknown-elf-objcopy
both commands work because I verified them with a nios2 elf
I also get it working using internal flash for code storage and alt_load for writable sections.
So that just leaves the "niosv_g_bootloader.srec" which replaced Nios2 "boot_loader_cfi.srec".
Can we be certain "niosv_g_bootloader.srec" works with Generic QSPI??
Great! - I confirmed "niosv_g_bootloader.srec" works just fine when using UFM internal flash to store software.
It doesnt work when using Generic QSPI.
Interestingly I notice that Nios 2 had a number of bootloaders . I used the one for CFI flash.
NiosV only has one for each version.Its not clear whether any of them support QSPI.
This is my last problem. Give me an answer to this and I can close this issue!
