JoshuaWillson
2 years agoMultiple NIOS V Implementation
Hi, I was looking at the NIOS V Processor Reference Manual. I could not find the max instantiations you can implement on a FPGA. I see many designs online of Nios II Multiprocessors. Can I make the ...
- 2 years ago
Unfortunately, the official support for Nios V to use Mutex HAL API is not yet supported.
You may implement them at your own accord and we may not be able to support further if you encounter issue.
With this, do you have any further questions?
Again, we apologies giving you this bad news.
PShar32
1 month agoI am try in to run multiple nios V, one is working perfectly fine other is not . I am using quartus 25. (Is this issue is resolved )
- ashutoshsriram1 month ago
I am facing the same issue , according to documents I have read (link below),ashling supports only 1 hardware thread therefore only 1 core can run at a time .please let me know if you find a way to implement this
https://www.scribd.com/document/979342170/How-to-Use-Ashalling-Riscfree
