In case you built your application and BSP folders using the Nios II command line, and you want to use Nios II IDE for debugging, kindly follow the steps below:
1- Make sure you have installed Eclipse along with Nios II Plugin. If not installed, follow the steps in this guide: 3.1. Installing Eclipse IDE into Nios® II EDS
2- Open Nios II IDE from Nios II command shell using eclipse-nios2 command. This ensures all the required env paths are available for the tool.
3- From File -> Import -> Nios II Software Build Tools Project -> Import Custom Makefile for Nios II Software Build Tools Project
4- Select the Project location. Do this twice to include the APP and BSP folders.
5- You should see the included directories inside the Project Explorer
Thank you,
Fawaz.
Hello Fawaz,
Thank you for your helpful advice.
I followed the instructions and finished the build project without any errors.
I can see that the build project executes "wsl make all".
" The "make" command should update the elf file, but it didn't, even though there were no errors.
Is this normal?
Why isn't the elf file being generated, even though there's a warning message in main.c about not finding the include file?
Thank you
Michael
