How to #include a driver from a IP component to my construction, in Nios II?
- 4 years ago
I think I got the construction to work now. The errormessage has disappeared. The file seems to be found.
Thanks for all help. Hareesh, you are a hero. I have asked others about this matter. You are the one that have guided me to an solution.
OK, many thanks for your help. It's very valuble for me. The idea isn't to use the drivers of the VGA IP. I gonna use my own drivers for the construction instead (that I know works perfectly). But for some reason (that I don't understand), the customer wants (demands), me to use his VGA IP to store my drivers in.
But the customer gets what the customer wants. I hope he likes the invoice I am gonna send him for the work.
I thougt it was an easy job just to link to his IP component from my construction thru an .tcl file.
The construction is almost finished and working, exept for the linking part. So I will not inplement his cunstrucktion (IP component), into mine in this stage. Becauce it will take me much more time (that I don't have at the moment).
But I will follow your tip to add his VGA IP and link to it from there. I will also com back to you with the result.
Best regards. Håkan.
