meenalkb
4 years agoHAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
In the user guide for the Generic Serial Flash Interface (GSFI) it says "altera_safeclib" must be enabled in the BSP editor to use the HAL API for this device.
With a Quartus 21.1 install and the a...
- 4 years ago
Hi Meenalkb,
To enable the Generic Serial Flash Interface (GSFI) use the HAL API and follow the below steps in Eclipse.
- BSP Editor->Nios II
- file paths of .sopcinfo and .bsp (new or old) in the open BSP window and click on open.
- A platform design window will be open in which you select the BSP software packages option. In that, just enable the altera_safeclib option.
- Select Generate BSP.
once the BSP generation is completed. Check in the drivers->inc and drivers->src folders. for
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/nios-ii-hal-driver.html
- intel_generic_serial_flash_interface_top.h
- intel_generic_serial_flash_interface_top.c
hareesh
4 years agowhich version are you using?
meenalkb
4 years agoQuartus 21.1.
