20 years agoQuick nios2-flash-programmer question
Hi.
Does anyone know if its possible to program multiple software (elf / flash) applications into a single flash device, where each program is located at a different address? If so, how may this be done? I saw another thread asking this very question, but the answer was to use the --offset tag with elf2flash, however, this tag does not seem to be supported anymore (was it ever?). Thanks a bunch, Kevin (P.S. Does anyone else have issues with the 'search' tool on this forum? It never returns decent results)2 Replies
two possibilities done with script files (not from ide)
nios2 .flash files are srec files 1. a) use elf2flash to generate flash-file from elf-file http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif use nios2-elf-objcopy to change address of srec file 2. a) use elf2flash to generate flash-file from elf-file http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif use nios2-elf-objcopy to generate binary file from flash-file c) use bin2flash to generate again flash-file at new offset sample script for 1. SRCNAME=hello_world_0 FLASH_OFFSET=0x100000 # where program is stored in flash SRC_FILE=./src/$SRCNAME.elf DST_FILE=./flash_files/$SRCNAME.flash DST_FILE_OFF="./flash_files/"$SRCNAME"_"$FLASH_OFFSET".flash" echo ---------------------------------------------------------------------------- echo "START elf2flash" FLASHBASE=0x000000 # BASEADDRESS OF FLASH FLASHEND=0x7FFFFF RESETADDRESS=0x000000 FLASH_ID=U1 BOOTLOADER=boot_loader_cfi.srec # BOOTLOADER echo "ELF FILE : "$SRC_FILE echo "FLASH FILE : "$DST_FILE echo "BOOTLOADER : "$BOOTLOADER echo "FLASH ID : "$FLASH_ID echo "FLASH BASE ADD : "$FLASHBASE echo "FLASH END ADD : "$FLASHEND echo "RESET ADD : "$RESETADDRESS elf2flash --input=$SRC_FILE --output=$DST_FILE --base=$FLASHBASE --end=$FLASHEND --boot=$BOOTLOADER --reset=$RESETADDRESS --flash=$FLASH_ID --verbose echo ---------------------------------------------------------------------------- echo "START objcopy" echo "INPUT FLASH FILE : "$DST_FILE echo "OUTPUT FLASH FILE : "$DST_FILE_OFF echo "OFFSET IN FLASH : "$FLASH_OFFSET nios2-elf-objcopy -v -I srec -O srec --srec-forceS3 --srec-len 32 --change-addresses $FLASH_OFFSET $DST_FILE $DST_FILE_OFF echo ---------------------------------------------------------------------------- echo "START quartus_programmer" BOARD_CONF_FILE=b12dal03_fpga.sof # PATH TO FLASH PROGRAMMER BOARD FILE JTAG_DEVICE=2 # NO OF DEVICE in JTAG_CHAIN echo "BOARD_CONF_FILE: "$BOARD_CONF_FILE echo "JTAG-DEVICE : "$JTAG_DEVICE quartus_pgm --cable="USB-Blaster [USB-0]" --mode=JTAG --operation="p;$BOARD_CONF_FILE@$JTAG_DEVICE" echo ---------------------------------------------------------------------------- FLASH_FILE=$DST_FILE_OFF BASEFLASH=0x00000000 # BASEADDRESS OF FLASH echo "START nios2-flash-programmer" echo "FLASH FILE : "$FLASH_FILE echo "JTAG-DEVICE : "$JTAG_DEVICE echo "FLASH BASE ADD : "$BASEFLASH nios2-flash-programmer --debug --device=$JTAG_DEVICE --accept-bad-sysid --base=$BASEFLASH $FLASH_FILE - Altera_Forum
Wowha! How did I miss all of those GNU tools?! Bonus! Thanks a bunch,
Kevin --- Quote Start --- originally posted by fischer@Aug 10 2006, 03:43 PM two possibilities done with script files (not from ide)nios2 .flash files are srec files
1.
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/cool.gif use nios2-elf-objcopy to change address of srec file
2.
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/cool.gif use nios2-elf-objcopy to generate binary file from flash-file
srcname=hello_world_0
flash_offset=0x100000 # where program is stored in flash
src_file=./src/$srcname.elf
dst_file=./flash_files/$srcname.flash
dst_file_off="./flash_files/"$srcname"_"$flash_offset".flash"
echo "start elf2flash"
flashbase=0x000000 # baseaddress of flash
flashend=0x7fffff
resetaddress=0x000000
flash_id=u1
bootloader=boot_loader_cfi.srec # bootloader
echo "elf file : "$src_file
echo "flash file : "$dst_file
echo "bootloader : "$bootloader
echo "flash id : "$flash_id
echo "flash base add : "$flashbase
echo "flash end add : "$flashend
echo "reset add : "$resetaddress
elf2flash --input=$src_file --output=$dst_file --base=$flashbase --end=$flashend --boot=$bootloader --reset=$resetaddress --flash=$flash_id --verbose
echo "start objcopy"
echo "input flash file : "$dst_file
echo "output flash file : "$dst_file_off
echo "offset in flash : "$flash_offset
nios2-elf-objcopy -v -i srec -o srec --srec-forces3 --srec-len 32 --change-addresses $flash_offset $dst_file $dst_file_off
echo "start quartus_programmer"
board_conf_file=b12dal03_fpga.sof # path to flash programmer board file
jtag_device=2 # no of device in jtag_chain
echo "board_conf_file: "$board_conf_file
echo "jtag-device : "$jtag_device
quartus_pgm --cable="usb-blaster [usb-0]" --mode=jtag --operation="p;$board_conf_file@$jtag_device"
flash_file=$dst_file_off
baseflash=0x00000000 # baseaddress of flash
echo "start nios2-flash-programmer"
echo "flash file : "$flash_file
echo "flash base add : "$baseflash
nios2-flash-programmer --debug --device=$jtag_device --accept-bad-sysid --base=$baseflash $flash_file
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17515)
--- quote end ---
--- Quote End ---
