20 years agoQuick nios2-flash-programmer question
Hi. Does anyone know if its possible to program multiple software (elf / flash) applications into a single flash device, where each program is located at a different address? If so, how may ...
20 years agotwo possibilities done with script files (not from ide)
nios2 .flash files are srec files 1. a) use elf2flash to generate flash-file from elf-file http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif use nios2-elf-objcopy to change address of srec file 2. a) use elf2flash to generate flash-file from elf-file http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif use nios2-elf-objcopy to generate binary file from flash-file c) use bin2flash to generate again flash-file at new offset sample script for 1. SRCNAME=hello_world_0 FLASH_OFFSET=0x100000 # where program is stored in flash SRC_FILE=./src/$SRCNAME.elf DST_FILE=./flash_files/$SRCNAME.flash DST_FILE_OFF="./flash_files/"$SRCNAME"_"$FLASH_OFFSET".flash" echo ---------------------------------------------------------------------------- echo "START elf2flash" FLASHBASE=0x000000 # BASEADDRESS OF FLASH FLASHEND=0x7FFFFF RESETADDRESS=0x000000 FLASH_ID=U1 BOOTLOADER=boot_loader_cfi.srec # BOOTLOADER echo "ELF FILE : "$SRC_FILE echo "FLASH FILE : "$DST_FILE echo "BOOTLOADER : "$BOOTLOADER echo "FLASH ID : "$FLASH_ID echo "FLASH BASE ADD : "$FLASHBASE echo "FLASH END ADD : "$FLASHEND echo "RESET ADD : "$RESETADDRESS elf2flash --input=$SRC_FILE --output=$DST_FILE --base=$FLASHBASE --end=$FLASHEND --boot=$BOOTLOADER --reset=$RESETADDRESS --flash=$FLASH_ID --verbose echo ---------------------------------------------------------------------------- echo "START objcopy" echo "INPUT FLASH FILE : "$DST_FILE echo "OUTPUT FLASH FILE : "$DST_FILE_OFF echo "OFFSET IN FLASH : "$FLASH_OFFSET nios2-elf-objcopy -v -I srec -O srec --srec-forceS3 --srec-len 32 --change-addresses $FLASH_OFFSET $DST_FILE $DST_FILE_OFF echo ---------------------------------------------------------------------------- echo "START quartus_programmer" BOARD_CONF_FILE=b12dal03_fpga.sof # PATH TO FLASH PROGRAMMER BOARD FILE JTAG_DEVICE=2 # NO OF DEVICE in JTAG_CHAIN echo "BOARD_CONF_FILE: "$BOARD_CONF_FILE echo "JTAG-DEVICE : "$JTAG_DEVICE quartus_pgm --cable="USB-Blaster [USB-0]" --mode=JTAG --operation="p;$BOARD_CONF_FILE@$JTAG_DEVICE" echo ---------------------------------------------------------------------------- FLASH_FILE=$DST_FILE_OFF BASEFLASH=0x00000000 # BASEADDRESS OF FLASH echo "START nios2-flash-programmer" echo "FLASH FILE : "$FLASH_FILE echo "JTAG-DEVICE : "$JTAG_DEVICE echo "FLASH BASE ADD : "$BASEFLASH nios2-flash-programmer --debug --device=$JTAG_DEVICE --accept-bad-sysid --base=$BASEFLASH $FLASH_FILE
