19 years agoQuastion about ucLinux under DE2!!(Help)
I try run the ucLinux under the DE2.
But when I create the FileSystem the IDE show that : "Warning: Total size of selected packages exceeds size of available memory on upload device." the Nios is build by my self not the system from the disk of DE2. i have no idea for this problem. is there have any document for the topic of running the ucLinux under the DE2? I need your help, thank you...2 Replies
--- Quote Start --- originally posted by askc037@Mar 3 2007, 03:20 PM i try run the uclinux under the de2.but when i create the filesystem the ide show that :
"warning: total size of selected packages exceeds size of available memory on upload device."
the nios is build by my self not the system from the disk of de2.
is there have any document for the topic of running the uclinux under the de2?
i need your help, thank you...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21977)
--- quote end ---
--- Quote End --- you can see http://nioswiki.jot.com/wikihome/operating...%c2%b5clinux, (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux,it) it can tell you how to running uclinux step by step
I found it .Thank you very much:)
