19 years agoQuastion about ucLinux under DE2!!(Help)
I try run the ucLinux under the DE2. But when I create the FileSystem the IDE show that : "Warning: Total size of selected packages exceeds size of available memory on upload device." the N...
19 years ago --- Quote Start --- originally posted by askc037@Mar 3 2007, 03:20 PM i try run the uclinux under the de2.
but when i create the filesystem the ide show that :
"warning: total size of selected packages exceeds size of available memory on upload device."
the nios is build by my self not the system from the disk of de2.
i have no idea for this problem.
is there have any document for the topic of running the uclinux under the de2?
i need your help, thank you...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21977)
--- quote end ---
--- Quote End --- you can see http://nioswiki.jot.com/wikihome/operating...%c2%b5clinux, (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux,it) it can tell you how to running uclinux step by step
