17 years agoquartus layout mess after sopc update
Hey boys and girls,
I met a problem, I have a quartus project used a Nios2 with one PIO and SDRAM, in quartus, I "layout" all lines or bus one by one, after long run compiling, it run on my board, I feel very happy. But yesterday, I need to add one PIO more, the modtity the SOPC and one PIO, re-gen it. But after update design in quartus, because of the growing nios2, my lines connected to SDRAM and old PIO MESS! I need to re layout them, it looks VERY stupid.... How can I work out the stuff? Thank you!!2 Replies
I don't think there's a way of avoiding that. If there is I wish I'd known it several years ago because I've always adjusted my wiring manually following an SOPC change. The only tip I can suggest is that before moving anything you turn off the button 'Use Rubber Banding' so that your wiring doesn't re-connect to the SOPC pin it now happens to align with. That way you can just draw boxes around blocks of wires/symbols and move them en-masse to the correct location. At least normally the existing ports are kept in the same order. Have fun. Sharkybaba - Altera_Forum
<div class='quotetop'>QUOTE (sharkybaba @ Jun 26 2009, 08:13 PM) <{post_snapback}> (index.php?act=findpost&pid=22920)</div>
--- Quote Start --- Hello, I don't think there's a way of avoiding that. If there is I wish I'd known it several years ago because I've always adjusted my wiring manually following an SOPC change. The only tip I can suggest is that before moving anything you turn off the button 'Use Rubber Banding' so that your wiring doesn't re-connect to the SOPC pin it now happens to align with. That way you can just draw boxes around blocks of wires/symbols and move them en-masse to the correct location. At least normally the existing ports are kept in the same order. Have fun. Sharkybaba[/b] --- Quote End --- My GOD.... Thank you VERY much!!
