17 years agoquartus layout mess after sopc update
Hey boys and girls, I met a problem, I have a quartus project used a Nios2 with one PIO and SDRAM, in quartus, I "layout" all lines or bus one by one, after long run compiling, it run on my bo...
17 years ago<div class='quotetop'>QUOTE (sharkybaba @ Jun 26 2009, 08:13 PM) <{post_snapback}> (index.php?act=findpost&pid=22920)</div>
--- Quote Start --- Hello, I don't think there's a way of avoiding that. If there is I wish I'd known it several years ago because I've always adjusted my wiring manually following an SOPC change. The only tip I can suggest is that before moving anything you turn off the button 'Use Rubber Banding' so that your wiring doesn't re-connect to the SOPC pin it now happens to align with. That way you can just draw boxes around blocks of wires/symbols and move them en-masse to the correct location. At least normally the existing ports are kept in the same order. Have fun. Sharkybaba[/b] --- Quote End --- My GOD.... Thank you VERY much!!
