ZhiqiangLiang
1 year agoqspi driver in NIOS bsp in Cyclone 10
Hi, I am running NIOS II in Cyclone 10 LP 10CL120YF484. The flash I am using is M25P64 which is qspi interface. The problem is that EPCS flash controller is not compatible for Cyclone 10. I am go...
ZhiqiangLiang
1 year agoThe question is not answered, why should I start a new thread?
if I created a new thread, should I copy all comments/questions to the new thread?
Archer_Altera
1 year agoHi Zhiqiang,
About the error you see when you do Eclipse-->Run-->Run Configurations and Run, Eclipse report the following error. My understanding is that you want to use eclipse tool to debug your design. It is an issue related to the design or tool usage. So, I suggest you to create a new thread.
About the issue of programming ELF file into flash, if you still need help, we can discuss it using this thread continuously.
Thank your for your understanding and cooperation.
