13 years ago
PTF file in Qsys?
While compiling uClinux, a command is required to send the hardware features and corresponding addresses i.e. "make vendor_hwselect SYSPTF='path to ptf file' ".
However PTF file is generated by SOPC. Newer version of SOPC, Qsys does not generate a PTF file.
To compile the uClinux for a environment created by Qsys, What can be used?
    --- Quote Start ---
    --- Quote End ---
    PTFs are no longer created, and the uCLinux build no longer requires you to run the hwselect command. Instead, you should create a device tree from the sopcinfo file using sopc2dts.
    --dalon
    --- Quote Start ---
    --dalon
    --- Quote End ---
    Thanks a lot. Can you provide me a fresh source of uClinux that does not require the hwselect and can run on Nios II?
    Thanks a lot dwesterg. I will start to deal with uClinux again.
