13 years agoPTF file in Qsys?
Hello, While compiling uClinux, a command is required to send the hardware features and corresponding addresses i.e. "make vendor_hwselect SYSPTF='path to ptf file' ". However PTF file is...
13 years ago --- Quote Start --- Hello, While compiling uClinux, a command is required to send the hardware features and corresponding addresses i.e. "make vendor_hwselect SYSPTF='path to ptf file' ". However PTF file is generated by SOPC. Newer version of SOPC, Qsys does not generate a PTF file. To compile the uClinux for a environment created by Qsys, What can be used? Thanks. --- Quote End --- PTFs are no longer created, and the uCLinux build no longer requires you to run the hwselect command. Instead, you should create a device tree from the sopcinfo file using sopc2dts. --dalon
