20 years ago
Programming of Timer Interrupt???
I have set up one NIOS2, one ONCHIP_RAM(4K), one INTERNAL_TIMER and four PIO in the SOPC builder. my board use 25Mhz osicllation.
I want to design a timer interrupt routine, just for glittering the LEDs.
int main (void) __attribute__ ((weak, alias ("alt_main")));
alt_u8 x = 0x5;
static void timer_interrupts(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_TIMER_STATUS(SYS_TIMER_BASE, 0);//clear TO
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, x);//light LEDs
if(x==5)x=0xA;
else x=5;
int alt_main (void)
alt_irq_register(SYS_TIMER_IRQ, (void*)&x, timer_interrupts);
IOWR_ALTERA_AVALON_TIMER_PERIODL(SYS_TIMER_BASE, 0xBC20);
IOWR_ALTERA_AVALON_TIMER_PERIODH(SYS_TIMER_BASE, 0xBE);
IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_TIMER_BASE, 7);
while (1)
return 0;
built complete!!!
when I downlaod program to EP1c12, but the console said verify failed http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
what&#39;s wrong with my routine???
the hardware is ok and i can download the hello_led routine.
    Is the RAM also connected to the data port of the processor?
    Verified failed? Sounds to me like memory problem. Have you check the .elf size is it <4k? or as svhb pointed out: is the data and address ports connected to the CPU?
