20 years agoProgramming of Timer Interrupt???
I have set up one NIOS2, one ONCHIP_RAM(4K), one INTERNAL_TIMER and four PIO in the SOPC builder. my board use 25Mhz osicllation. I want to design a timer interrupt routine, just for glittering ...
20 years agoVerified failed? Sounds to me like memory problem. Have you check the .elf size is it <4k? or as svhb pointed out: is the data and address ports connected to the CPU?
