21 years agoProblems with NIOS II Build
Has anyone noticed any problems with Nios II on Quartus 4.2?
Specifically I've upgraded to Quartus 4.2 and am running NIOS II sp 1 When doing a build at the final stages I get a make -s all Syntax error: "(" unexpected make: *** [C:/altera/NIOS/blmcore2/full_1c20_sim/dummy_file] Error 2 Build completed Now the elf seems to be built correctly as it can be downloaded and run but this error stops the flash programmer running (since it always does a build). It seems that the error is due to a problem in one of the auto generated make files but it is pretty hard to find out where, any suggestions? (To try and trace the problem I've tried it on a different OS boot and also tried re-installing NIOS II sp1 back over top but the error persists) ...Regards4 Replies
Do you have access to Nios II 1.1? If so, I'd recommend using it.
- slacker - Altera_Forum
According to Altera,
'Quartus 4.2, is not compatible with NIOS II SP1, and this fact will be added to the Quartus 4.2 pages in a promiment place'. Hey ho, and no i don't have access to it so will just have to wait for the 20% compilation speed increase when Nios 1.1 arrives. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Altera_Forum
Can you use the eval version available through the forum till the CD arrives?
Hello cybdenw,
I "solve" this problem by doing this : - run your project, it will compile and give the error you mentionned - delete the dummy_file - create a new text document - rename it as dummy_file - re-run your project, it will finish the interrupted compilation (actually rebuild the flash images), it should work. I know it is very annoying to have to do so, but it is the only way I found.... Hope it helps, Yours
