21 years agoProblems with NIOS II Build
Has anyone noticed any problems with Nios II on Quartus 4.2? Specifically I've upgraded to Quartus 4.2 and am running NIOS II sp 1 When doing a build at the final stages I get a make -s...
21 years agoHello cybdenw,
I "solve" this problem by doing this : - run your project, it will compile and give the error you mentionned - delete the dummy_file - create a new text document - rename it as dummy_file - re-run your project, it will finish the interrupted compilation (actually rebuild the flash images), it should work. I know it is very annoying to have to do so, but it is the only way I found.... Hope it helps, Yours
