17 years ago
problem with triple speed ethernet for custom board
I'm a newbie to uclinux
trying to connect to a custom board
I get the following errors when using the tse (experimental) in uclinux
am I missing any driver
or are there any changes that i've to do in any files
In file included from /home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1084:
/home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:30:2:# error "**** This build has not been configured with Alteras example design of TSE-SGDMA."
/home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:31:2:# error "**** You need to do: make vendor_hwselect SYSPTF=<your_path>/NiosII_stratixII_2s60_RoHS_TSE_SGDMA_sopc.ptf"
/home/dpatloll/nios2-linux/linux-2.6/include/../drivers/net/atse.h:32:2:# error "**** Or, You need to unselect ATSE ethernet driver with make menuconfig"
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c: In function `atse_device_init':
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: `na_tse_mac_control_port' undeclared (first use in this function)
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: (Each undeclared identifier is reported only once
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1153: error: for each function it appears in.)
make[3]: *** [arch/nios2/kernel/config.o] Error 1
make[2]: *** [arch/nios2/kernel] Error 2
make[2]: *** Waiting for unfinished jobs....
the following errors are in uclinux when i'm using the tse mac (SLS)
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: `na_tse_mac_control_port' undeclared here (not in a function)
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1169: error: (near initialization for `alt_tse_resource[0].start')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1170: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1170: error: (near initialization for `alt_tse_resource[0].end')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1173: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1173: error: (near initialization for `alt_tse_resource[0]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1179: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1179: error: (near initialization for `alt_tse_resource[1]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1185: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1185: error: (near initialization for `alt_tse_resource[2]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1191: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1191: error: (near initialization for `alt_tse_resource[3]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1197: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1197: error: (near initialization for `alt_tse_resource[4]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1203: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1203: error: (near initialization for `alt_tse_resource[5]')
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1211: error: initializer element is not constant
/home/dpatloll/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:1211: error: (near initialization for `alt_tse_resource[6]')
someone please let me know ..what might be the problem
again I'm a newbie to this whole nios and uclinux thing
thank you
    what is the name of your tse mac in sopc builder? did you change the platform driver setup in config.c to match that name?
    --dalon
    --- Quote Start ---
    --dalon
    --- Quote End ---
    Thank you for the response
    my tse mac is named ethernet
    do i have to change it (to something like tse_mac)
    what changes do i have to make in the config.c
    please let me know
    if you look at the config.c file, all the (or most of) the peripherals are defined using the swinfo2header command generated .h file# defines from an example design. that means that you either need to modify your sopc system to match the names of the example design's components, or modify the confic.c platform driver instances to reference the correct# defines for your system.
    --dalon
