17 years agoproblem with triple speed ethernet for custom board
I'm a newbie to uclinux trying to connect to a custom board I get the following errors when using the tse (experimental) in uclinux am I missing any driver or are there any changes that i've...
17 years agoif you look at the config.c file, all the (or most of) the peripherals are defined using the swinfo2header command generated .h file# defines from an example design. that means that you either need to modify your sopc system to match the names of the example design's components, or modify the confic.c platform driver instances to reference the correct# defines for your system.
--dalon
