20 years agoproblem with sdram on nios2 dev kit
Hi
I have some problems getting started with my nios2 dev-kit. The dev kit is a stratix2 EPS2S60 board. I have tried with both verison 5.1 and 6.0 of the dev-tools. In the nios2 ide "getting started" tutorial I got this error message as I tried to run my project as nios2 hardware:Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x021208B8: verified
Initializing CPU cache (if present)
OK
Downloading 01000020 ( 0%)
Downloaded 1KB in 0.0s
Verifying 01000020 ( 0%)
Verify failed between address 0x1000020 and 0x10000DF
Leaving target processor paused A memtest gave me the following: Testing RAM from 0x1000000 to 0x1FFFFFF
-Data bus test passed
-Address bus test failed at address 0x1000004
Press enter to continue... onchip_ram, ext_ram and ext_flash works fine, but the sdram is no-go. I appreciate any help.1 Reply
Good news!
I solved the problem. I adjusted the pll clock phase shift for sdram_clk_out from default -3.50ns to -4.0ns
Strange that the dafault settings didn't work on a development board...Testing RAM from 0x1000000 to 0x1FFFFFF -Data bus test passed -Address bus test passed -Byte and half-word access test passed -Testing each bit in memory device. . . passed -Testing memory using DMA. passed Memory at 0x1000000 Okay Press enter to continue...
