21 years agoproblem ,when i chose "debug as niosII hardware"
project build has been succeed ,but when i chose "debug as niosII hardware".
System hints: you have more than one jtag cable available so you must use the --cable optionto choose between them (or open the "run/run" or "run/debug" dialog and go to
the "target connection" tab).
no --cable option was provided (or you selected automatic) what is the reason?how to solve it?
1 Reply
It looks like you may have multiple cables installed. To pick the intended cable eg. USB-Blaster, go to the menu bar and select Run -> Debug... Select the Target Connection tab and select the cable of your choice from the drop-down list for the JTAG cable field. Then click on Debug, to start the session.
