21 years agoproblem ,when i chose "debug as niosII hardware"
project build has been succeed ,but when i chose "debug as niosII hardware". System hints: you have more than one jtag cable available so you must use the --cable option to choose bet...
21 years agoIt looks like you may have multiple cables installed. To pick the intended cable eg. USB-Blaster, go to the menu bar and select Run -> Debug... Select the Target Connection tab and select the cable of your choice from the drop-down list for the JTAG cable field. Then click on Debug, to start the session.
