13 years ago
Problem when downloading zImage to DE2-115 (cont.)
--- Quote Start ---
This is jpe1313,
What I was saying was that are any of your entries your generated *.dts file "unknown." Take a look. If they are "unknown" then it COULD be a problem. For my custom design my "timer" was undefined and I had to define it properly. As far as the SD card. To clarify, I am not using the SD card in my design. I have a daughter card that has a Compact Flash.
Let me know if you need more help - but check your DTS
--- Quote End ---
I am not able to post without administrator's approval. So i sent my message here. I maybe wrote 5-6 times both topics but it seems all admins are sleeping. Please email me (occelebi at gmail) Because i can not send any message more than 1
Anyway, i have no unknown parameters.
* This devicetree is generated by sopc2dts on Fri Apr 19 16:30:38 EEST 2013
* Sopc2dts is written by Walter Goossens <[email protected]>
* in cooperation with the nios2 community <[email protected]>
/dts-v1/;
model = "ALTR,onur";
compatible = "ALTR,onur";
# address-cells = < 1 >;
# size-cells = < 1 >;
cpus {
# size-cells = < 0 >;
cpu: cpu@0x0 {
device_type = "cpu";
compatible = "ALTR,nios2-12.1";
reg = < 0x00000000 >;
interrupt-controller;
# interrupt-cells = < 1 >;
clock-frequency = < 50000000 >; /* embeddedsw.CMacro.CPU_FREQ type NUMBER */
dcache-line-size = < 32 >; /* embeddedsw.CMacro.DCACHE_LINE_SIZE type NUMBER */
icache-line-size = < 32 >; /* embeddedsw.CMacro.ICACHE_LINE_SIZE type NUMBER */
dcache-size = < 2048 >; /* embeddedsw.CMacro.DCACHE_SIZE type NUMBER */
icache-size = < 4096 >; /* embeddedsw.CMacro.ICACHE_SIZE type NUMBER */
ALTR,implementation = "fast"; /* embeddedsw.CMacro.CPU_IMPLEMENTATION type STRING*/
ALTR,pid-num-bits = < 8 >; /* embeddedsw.CMacro.PROCESS_ID_NUM_BITS type NUMBER */
ALTR,tlb-num-ways = < 16 >; /* embeddedsw.CMacro.TLB_NUM_WAYS type NUMBER */
ALTR,tlb-num-entries = < 256 >; /* embeddedsw.CMacro.TLB_NUM_ENTRIES type NUMBER */
ALTR,tlb-ptr-sz = < 8 >; /* embeddedsw.CMacro.TLB_PTR_SZ type NUMBER */
ALTR,has-mul; /* embeddedsw.CMacro.HARDWARE_MULTIPLY_PRESENT type NUMBER*/
ALTR,reset-addr = < 0xc0000000 >; /* embeddedsw.CMacro.RESET_ADDR type NUMBER */
ALTR,fast-tlb-miss-addr = < 0xc8001000 >; /* embeddedsw.CMacro.FAST_TLB_MISS_EXCEPTION_ADDR type NUMBER */
ALTR,exception-addr = < 0xc0000020 >; /* embeddedsw.CMacro.EXCEPTION_ADDR type NUMBER */
}; //end cpu@0x0 (cpu)
}; //end cpus
memory@0 {
device_type = "memory";
reg = < 0x08001000 0x00000400
0x00000000 0x08000000 >;
}; //end memory@0
sopc@0 {
device_type = "soc";
ranges;
compatible = "ALTR,avalon", "simple-bus";
bus-frequency = < 50000000 >;
jtag: serial@0x8001440 {
compatible = "ALTR,juart-12.1", "ALTR,juart-1.0";
reg = < 0x08001440 0x00000008 >;
interrupt-parent = < &cpu >;
interrupts = < 1 >;
}; //end serial@0x8001440 (jtag)
timer: timer@0x8001420 {
compatible = "ALTR,timer-12.1", "ALTR,timer-1.0";
reg = < 0x08001420 0x00000020 >;
interrupts = < 0 >;
}; //end timer@0x8001420 (timer)
}; //end sopc@0
chosen {
bootargs = "debug console=ttyJ0,115200";
}; //end chosen
}; //end /
And i also made my friend compile my kernel and .sopc file and tried to new zImage but terminal gave me same output :/
root@F15:~# altera/12.1/nios2eds/bin/nios2-download -g /home/student/Downloads/zImage
Using cable "USB-Blaster [8-1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
I hope you can even help further.
Cem
