13 years agoProblem when downloading zImage to DE2-115 (cont.)
--- Quote Start --- This is jpe1313, What I was saying was that are any of your entries your generated *.dts file "unknown." Take a look. If they are "unknown" then it COULD be a problem....
13 years agoThank you, finally it works !
root@F15:~# altera/12.1/nios2eds/bin/nios2-download -g /home/student/luclinux/uClinux-dist/linux-2.6.x/arch/nios2/boot/zImage Using cable "USB-Blaster [8-1]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 1421KB in 28.6s (49.6KB/s) Verifying C1000000 ( 0%) Verify failed between address 0xC1000000 and 0xC100FFFF Leaving target processor paused And i also wonder that how to make it work ? But now i am stucked on nios2-terminal. root@F15:~/altera/12.1/nios2eds/bin#./nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [8-1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) It stucks on there.
