20 years ago
Problem when changing FMAX of system
Hi,all!
I try to increase the working frequency of NIOSII processor on 1s40 board.
Following is what I do:
1. copy the example design "standard" from the install directory "altera/kits/nios2/example".
2. change the c0 out put of PLL to a higher frequency, for example, 60MHz.
3. change the system frequency in sopc builder to 60MHz, too.
4. save&compile
I have done the same thing months ago, and got no problem. But this time the system just don't work. After compilation and download the sof file to my board, I try to run some simple program like "hello world", but it doesn't work. Why did that happen? Thank you for any suggestions!
    If you are using Nios II/Quartus II 5.1 be sure to upgrade to at least Quartus II 5.1 SP1.
    When you say it doesn't work what warnings/errors are you seeing?
    Have you also increased the SDRAM clock? Or maybe the SDRAM timing isn't correct and you need to recalculate the phase shift.
