20 years agoProblem when changing FMAX of system
Hi,all! I try to increase the working frequency of NIOSII processor on 1s40 board. Following is what I do: 1. copy the example design "standard" from the install directory "altera/kits/n...
20 years agoHave you also increased the SDRAM clock? Or maybe the SDRAM timing isn't correct and you need to recalculate the phase shift.
