17 years agoProblem using NIOSII command terminal
while initializing the nios2 command window I see the message
13 [main] bash 4780 fork:child 5836- died waiting for long jump before initialization, error 11 bash :fork: resource temporary unavailable I think there is some memory issue... Can any1 tell me how can I clear it ??? Thank you in advance .....3 Replies
There are well known conflicts between Cygwin and various device drivers, particular the webcam drivers from Logitech. Disable the webcam drivers and I think you'll have better luck...provided that this is what's causing your issue, that is :-)
Cheers, - slacker - Altera_Forum
http://www.nioswiki.com/operatingsystems/u...x/tryoutuclinux (http://www.nioswiki.com/operatingsystems/uclinux/tryoutuclinux) I was working on uClinux , the configuration file I took was for 7.2 version. Does anybody think that it will work for altera version 9.0 too ????? - Altera_Forum
<div class='quotetop'>QUOTE (slacker @ Aug 27 2009, 01:04 PM) <{post_snapback}> (index.php?act=findpost&pid=23622)</div>
--- Quote Start --- There are well known conflicts between Cygwin and various device drivers, particular the webcam drivers from Logitech. Disable the webcam drivers and I think you'll have better luck...provided that this is what's causing your issue, that is :-) Cheers, - slacker[/b] --- Quote End --- You are right, I run into the same problem, and after disabling the camera, I could finaly compile my project with Nios EDS Thanks, Aurelio
