16 years agoproblem to run nios2-terminal
I have installed Quartus and nios2 9.1 sp2 on centOS5 to use uclinux. Now i am using the example of the Nios Community WIKY called TryOutuClinux on DE2 board. I have downloaded the sof and and the kernel image but i cannot run correctely the nios2-terminal.
This is what happens in my shell: " [NiosII EDS]$ nios2-configure-sof Searching for SOF file: in . DE2_NIOS_HOST_MOUSE_VGA.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;./DE2_NIOS_HOST_MOUSE_VGA.sof Info: Using programming cable "USB-Blaster [USB 5-1.2]" Info: Started Programmer operation at Wed Jun 30 10:28:44 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020B40DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Wed Jun 30 10:28:46 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 59 megabytes Info: Processing ended: Wed Jun 30 10:28:46 2010 Info: Elapsed time: 00:00:03 Info: Total CPU time (on all processors): 00:00:00 /tmp/primo_es_ulinux [NiosII EDS]$ nios2-download -g Using cable "USB-Blaster [USB 5-1.2]", device 1, instance 0x00 Pausing target processor: OK Restarting target processor /tmp/primo_es_ulinux [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 5-1.2]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) " And after this nothing appears on my screen Thank you very much for every help2 Replies
I think the problem is becuse when i download the linux image in the terminal i have only:
"Pausing target processor: OK Restarting target processor " and after this the image is not really downloaded, but i don't know how to solve this problem - Altera_Forum
Sorry, i am solved the problem, the nios2-download doesn't search the image file in the folder as the command nios2-configure-sof so i need only insert the image name after the command.
Now i can run the terminal. Sorry for this unseful thread.
