16 years agoproblem to run nios2-terminal
I have installed Quartus and nios2 9.1 sp2 on centOS5 to use uclinux. Now i am using the example of the Nios Community WIKY called TryOutuClinux on DE2 board. I have downloaded the sof and and the ke...
16 years agoSorry, i am solved the problem, the nios2-download doesn't search the image file in the folder as the command nios2-configure-sof so i need only insert the image name after the command.
Now i can run the terminal. Sorry for this unseful thread.
