16 years agoproblem of install the NIOS2eds
I would know if somebody faced the problem of installation of NIOS2-IDE under Linux, You think that it is the version of Linux that I use who provokes this problème.I work with ubuntu version 8.103 Replies
I have been able to install Quartus in Suse 10.1 Linux to be able to use the NIOS2 IDE. You can use the NIOS2-IDE without installing a license for Quartus itself.
-Michael - Altera_Forum
The problem which I faced it is to install NIOS2-IDE under ubuntu 8.10 Knowing that I installed quartus II 9.1 Web edition (without license) with no problem at all. if somebody can help me because it is a main part for me now in my project.Because without NIOS2-IDE I can't integre the kernel µclinux in the NIOS II. - Altera_Forum
That is what I tried to say. AFAIK, the NIOS2-IDE is part of the Quartus distribution and installs with same. So if you do have Quartus, you should already have NIOS2-.IDE.
Anyay: this forum's issue is embedded Linux running on NIOS, not using Linux on a PC, so you better ask over in a Quartus centric forum. -Michael
