16 years agoproblem of install the NIOS2eds
Hello, I would know if somebody faced the problem of installation of NIOS2-IDE under Linux, You think that it is the version of Linux that I use who provokes this problème.I work with ubuntu ve...
16 years agoThat is what I tried to say. AFAIK, the NIOS2-IDE is part of the Quartus distribution and installs with same. So if you do have Quartus, you should already have NIOS2-.IDE.
Anyay: this forum's issue is embedded Linux running on NIOS, not using Linux on a PC, so you better ask over in a Quartus centric forum. -Michael
