19 years agoProblem in using Avalon_Tristate_slave...
I am currently using " Altera Stratix 1S10 Development Kit". In SOPC Builder, I wanted to connect my User Logic to Nios Processor through Avalon_Tristate_slave. The Entity Interface in VHDL code of my User logic [Inverter]is: entity pipeline is Port ( clk : in std_logic; reset : in std_logic; cs : in std_logic; -- chipselect wr : in std_logic; -- write rd : in std_logic; -- read Outen : in std_logic; -- outputenable dio : inout std_logic_vector(31 downto 0)); -- Data Bidirectional end pipeline; Here, I tried to add this New Component in SOPC builder. While editing the componet by "Component Editor" wizard, I have chosen Avalon_tristate_slave_0 in Interface-Tab. Then in Signals Tab, Signal type option for this bidirection signal: " dio" is not indicating the type "Data". So by this, the Component is NOT Set as "OK" by Editor. So I am unable to proceed. I have gone through the document "mnl_avalon_spec.pdf", there I found this is the minimum requirement of signals to be done, for Tristate Bus Interface. Then What would be the problem, Can anyone help me out?? Regards, K V Naresh
