20 years agoProblem in using Avalon_Tristate_slave...
Hello, I am currently using " Altera Stratix 1S10 Development Kit". In SOPC Builder, I wanted to connect my User Logic to Nios Processor through Avalon_Tristate_slave. The Entity Inte...
20 years agoYou don't always need the tri-state bus.
The tri-state bus is needed mostly when you want to share pins with cfi flash or sdram. eg, smc91111. It is easier to build the component without avalon tri-state bus, and make your io port data bus tri-state with logic. eg, lcd or many others on DE2 board.
