15 years agoProblem booting program from EPCS flash and running from SRAM
Hardware and software tools:
NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.The problem as described in the title keeps popping up frequently in this forum so it might be a good idea to post the solution (step by step) in "Sticky" messages.Anyhow,i am facing the following problem - I have the FPGA and software tools and i also possess EPCS128 flash and 8 MB SRAM.I want to boot the Nios II program from EPCS and run in 8 MB SRAM.At this point i am able to run the program only in debug mode.In order to solve the issue I have tried the following solutions: http://alteraforums.net/forum/showthread.php?t=20623 --->I have reached the point when i created the joint (concatinated) hw+sw bin file and i have no idea what to do next (I saw that this is impossible to burn that file to flash using the console programmer ,maybe some conversion is required?) http://www.altera.com/support/kdb/solutions/rd12092009_471.html -->Trying to create .jic file and then burn that file using Quartus programmer.I have succeeded in doing this ,but the program still won't run after power-off and power-on,meaning it has not been programmed properly.Maybe the problem lies in the fact that the *.elf file used was from "Debug" directory and not "Release" (For some reason,the option of 'Release' has disappeared from IDE and i am not able to find that option anywhere). Any help would be appresciated Thank You very much, Michael
