15 years agoProblem booting program from EPCS flash and running from SRAM
Hardware and software tools: NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.The p...
15 years agothe connections are fine.The memory just goes from 0x0 and 0x7ffff.After setting THOSE boundaries ,memory test goes ok,though sopc builder address range is between 0x0 and 0xfffff.Nothing i can do about that ,because that seems to be default.I use Cypress-like SRAM (ISSTIS61VPS51236A 512x36)- It has same pinout as of cypress.I have noticed this problem keeps popping up over and over again along the years(i ran into posts dating back to 2005)
